Limited to stock on hand.
Due to the high cost of production and distribution, these tanks are being discontinued. We have a limited supply of natural finish and a few black tanks left.
Once these are gone, we willnot be able to get anymore.
CNC FABRICATION Coolant Tank: 748 / 916 / 996 / 998
$199.95
This water tank is a complete replacement of the factory part, just unscrew your factory cap and screw it onto this tank.
Tank has all OEM provisions for mounting accessories, and does not require any other modifications to be installed. This will eliminate all the issues with the OEM tanks leaking.
CNC FABRICATION Coolant Tank: 748 / 916 / 996 / 998 - Black Limited Edition
$229.95
This tank is a limited edition black anodized, the cost in anodize is extremely high due to the labor involved to ensure the tank is thoroughly clear of all chemicals through the multistep electro polishing and anodizing process. This tank also does not have provisions for the air sensor as seen on the original tanks, this location was welded and sealed. You can attach this sensor with double stick tape onto the surface or delete the sensor (common on race / track bikes.
Installation instructions and pictures:
http://motowheels.com/attachment/41245-.pdf
* Register on the Motowheels website for Free forum passwords to access discounts on most non sale items. Look for memberships and choose the membership type that fits you the best
