Yes, one air bleed screw seems totally stuck. It is in brand new condition. The other was loose from the get-go and I could turn it easily using a screwdriver.do you mean the air bleed screws are stuck? you could try some penetrant around them, or try to heat the throttle body casting.
the sync screw is between the throttle bodies, bugger to get to.
