A carbon heat guard will look pretty but it won't last since it's just way to close to the pipe and that section of the pipe will be very hot as most already found out so the guard will suffer with time.....
Neither does the carbon reflect the heat, as many think it does so it won't help with the heat at all.
Something special is in the works that will withstand the extreme heat and also will reflect it away from the rider.
