Posted in 'Sportclassic' forum, but as some of us share the same block I'll try here as well......
Hope someone can shed some light on this for me..... Work done by qualified mechanic and 2v owner, assisted by the Noddy that owns the bike.
Heads are on the block, in the bike.
Starting with V Exhaust then V Inlet changed split rings and rechecked clearance.
No issues doing the Vert head at all. Continued with H Inlet and H Exhaust.
Horiz Inlet: After removing opening shim closing shim appeared bound to valve stem, pushing closing rocker also took valve and shim with it so unable to remove split rings. Held valve stem and used a socket over the stem with plastic screwdriver handle to very gently tap [and I do mean gently] closing shim to free it up. Changed split rings, measured clearances, replaced opening shim, rocker and clip. Moved on to H Exhaust.
Horiz Exhaust closing shim also bound to valve stem, released in same manner as H Inlet closing shim, changed split rings, measured clearance.
Replaced opening shim. Found we were unable to slide opening rocker back over opening shim, If opening shim is removed rocker can slide freely back over the valve stem.
Checked if there is clearance between rocker and opening shim when fitted. There is at least 10 thou between the rocker and shim so something [cam?] is stopping the rocker from coming back over the shim.
Appears as if inlet valve is bound or locked or on the cam in the wrong position, unable to rotate cam thru 360*. Does rotate forward about 90deg then stops, will not rotate backward. Checked if piston at TDC is prohibiting valve movement as belt is off, rotated crank forward and back 90* from TDC but still not able to cycle through 360*.
Checked for foreign items, confirmed nothing fallen into head locking cam or rockers.
Removed inlet rocker keeper clip, unable to move inlet rocker off opening shim for further investigation. Rocker not under load.
Nothing was overly difficult, nothing forced, nothing to indicate an issue with the Horiz inlet side at all.
Has anyone been here before? I have read that split rings may not be seated correctly- possibility for the inlet but unable to check.
