1 - 2 of 2 Posts
ok how easy is it to convert my GT1000 to an open dry clutch?, is it a case of changing the engine case?
Will a multistrada case fit?
Your cases will be fine you would either need machinist to make a few bits for the input transmission shaft and inner basket or if the motor is apart just swap in the gearbox from a 1000SS then build the clutch as a 1000ss using all factory parts and nothing modified. By the sprocket is a 6mm screw that needs changing but that is easy too.
2 other ways.
1. Buy a 1000ss motor and swap it.
2. See if Ducati still has the conversion kit, I installed one in a 848 a few years ago and it was a good kit, not cheap but everything was there. This included the slipper clutch but I recommend street bikes do NOT run dry slipper clutches because they are more of a pain than a benefit on the street.
1 - 2 of 2 Posts
