Interesting! Does this introduce bubbles or are there so few that it gets pushed up towards the reservoir anyway, no bleeding required afterwards? Do you have to modify the tip of the syringe or is it good out of the box?amullo said:+1 on flushing the system.
Getting all the air out of an empty hydrallic system is a pain.
I use a big 500cc plastic syringe (buy from any pharmacy) and suck almost all the fluid out of the reservoir. Refill the syringe from a new bottle and PUSH that new fluid from the bottom bleeder bolt UP towards the pump and reservoir.
That way you aren´t working against the air, since it wants to rise to the top anyhow. Works in 2 minutes on my front brakes and clutch. Rear is abit more difficult, but the same principle.
Yes, it is!rearviewmirror said:This is an awesome deal on the top bleeder system from Mityvac, it usually sells for $80-100.
How do you keep the fluid from leaking out of the slave bleeder? Even with a hose clamp it leaks quite a bit.amullo said:+1 on flushing the system.
You've got the syringe attached to the slave nipple or the master nipple?dartfrog said:I refresh from the top down. I use a B&D syringe from the pharmacy then get a length of aquarium air tube. Attach it to the syringe the other end to the bleeder nipple.
After refilling the resivoir with new fluid, crack open slightly the bleeder then sloooowly pull the fresh fluid down. Once you see clean fluid stop. and your done. Throw tube abd syringe away or stash it in a plastic container for the next time.
