I installed a Ducati Performance Quickshifter on my '07 1098 today but can't wrap my head around how it works, sort of.
I assume the wiring to the kickstand switch fools the ECU in thinking that the stand is down for a split second to cut spark. Am I accurate here? Then the other connector, which hooks into the rear brake light switch harness I'm lost on, other than it being the power source. Am I in the ballpark here guys?
Just trying to figure it out if I have any issues as I'm testing it tomorrow at the track. All parked tests with the leds for setting cutoff time, sensativity, and neutral went well.
Thanks for any help you can lend!
