1 - 6 of 6 Posts
What bike would a DP Bucci slipper with a 24mm nut for the primary shaft fit?
And would a Slipper from a 999 fit a 996SPS? Many thanks Swanny.
Think all dry ducati clutches are the same, not 100% sure though
Thanks chaps, but does anyone know what the nut size (item no.6 in the exploded diagram) should be? For example is the 24mm nut standard or for an RS bike? Thanks.
Problem solved 24mm nut is from an RS/Corse 996/998 or 999 and a standard nut is 20mm! Thanks for the input guys.
1 - 6 of 6 Posts
