I've got my Mobil 1 20w-50 bike oil, new K&N 153 filter, and crush washers for the drain plug and filter screen, and the tools I should need. I don't want to start an oil thread, but the Mobile 1 made a noticable drop in running temp on my 900SS/FE, so I thought I'd give it a run in the Hyper.
This is the first time I've done an oil change on my Hyper, though I've done dozens of oil changes on my own bikes. The bike has around 4k on it, and it hasn't been changed since the first service around 700 miles. I'm kind of neurotic about my stuff and I'd like to check/clean the filter screen, even though it's probably not necessary. It looks like I'll need to drop the front header pipe to get it out of the way, and I guess my question is how you guys usually do it so you don't have to try to move a hot pipe. Do you get the bike hot, drain the oil, and then just wait until everything has cooled off before you try to move the pipe and pull the filter screen?
Any other tips or suggestions?
