Does the 848 have a 25mm front axle?
11490 14
Does the 848 have a 25mm front axle or is it the same as the 1098 (30mm)??
Thanks
Greg
1 - 15 of 15 Posts
The 848, HM, 999 series and 1098 use the same front wheel.
They all have a 25mm axle. The stepped spacer on the right side of the axle is 30mm.
-M
So to put a 999 front wheel on my race 848 all I need to do is use my 848 front axle, spacers and rotors? Do I need to swap the bearings and inner spacer on the 999 wheel.
Thanks Greg
Thanks Greg
Most of the superbikes run the 25/30 mm front axle bolt. I can't recall ever pulling one any other size than that. SO the bolt itself will go through the hole of the 999 wheel. I can't say for sure if the rest of it will work but I don;t see why not. The only thing I could think that would be different is the rotor bolt mounting. Some are 5 bolt & some are 6. But if you're using the 999 rotors too I'd think it'd work.
Just the axle and spacers, I have 1198 Ohlins forks on my 916 and am using a 916 wheel, only needed the 1198/1098/848 axle and spacers (albeit a larger spacer for the left side to fill the recess left by the mechanical speedo drive). Both 916 and 1198 use a 25mm axle as does 999/749, bearings and inner spacers will be OK.
I had to get new rotors as the offset is 5mm bigger but I believe that 999 has the same 15Mmm offset as 848? if so you don't need to swap them.
A useful tip; 916 front fender fits perfectly on 1198/1098/848 forks so if you're after a fancy CF part you can use a 916/748/996/998 fender which can often be found for less money than the newer 848/1098/1198. ;)
what about rear wheels? what are the sizes and interchangeabilities?
rears are another story. Even the 848 wheel is NOT interchangeable with the 1098/1198. It has a smaller bore. The single sided Monster rears will fit a 748/996/998 as will the Multi rear wheel. I also believe the Streetfighter shares the same rear with the 1098/1198
So to break it down on the rears:
*edit* 848 rear is same as all single sided swing arms EXCEPT 1098/1198/SF
748/996/998 is good on all those & Monster S2R, S4R S4RS, Multi
1098/1198/Streetfighter/1200 Multi are interchangeable.
If any of this info is wrong feel free to correct me but I think it's right
so a 999 or 1098 or 848 or 1198 wheel will fit my 748?
no, different number of screws per brake disc, different off-set
848 rear is ONLY good on an 848
no, 848 rear is same size as hypermotard and does fit all single sided
swingarms but the 1098/1198 ones.
OK, I didn't know about the Hyper& I swore the 848 was bigger than the earlier bikes. Sorry for the mis information people. I should go back & edit so as not to perpetuate false info :p
I also just checked & found out the new Multi 1200 shares the same rear wheel as the 1098/1198 & SF
Actually, yes the WHEEL will fit but the rotor offset will be different and you may need spacers. I use an 848 wheel and rotors with a 748 axle and 999R forks with no problems. It's s track bike so I didn't need speedo drive. I did need spacers for the brake calipers.
1 - 15 of 15 Posts
