Looking to run the rear cylinder pipe through the frame to the right side of the bike to merge with the other pipe. I see Corse makes a crankcase breather riser to clear a pipe but there's ZERO information on what models it works with. Has anyone used this on the SC?
That's a knock of of the Nichols breather. Corse Dynamics is basically their outsourced knock off line that they copy others designs. Just get the nichols.
Sent from my SM-G950U using Tapatalk
If you are asking what engines it will fit the cases are mostly the same unless you are talking much newer designs.
