1 - 7 of 7 Posts
I need your opinion. I just changed the oil on my 1098 and noticed a green tint on the oil that came out when compared to the fresh oil I was about to use. I am not sure if this is normal with this brand of oil,Ipone R4000 10-40 synthesis? Or I have a big problem?
Is there a sure way to tell. No smoke coming out of the exhaust and it seems to run fine.
I tried to check the coolant level but it's impossible to get the rad cap off without taking "half" of the front end of the bike off.
how much is a head gasket replacement, if that is the problem.
Any thoughts or comment would be greatly appreciated.
New oil on the left and oil with 1000km on it on the right
Id say your fine (no coolant) Anytime Ive seen coolant in the oil it turns a milky gray depending how much coolant is present. And a lot of times it will totally seperate out with the coolant going to the bottom.
I got two pieces of electrical tape on the coolant resevoir , one cold level and one hot level.When on the side stand ...
I check it every couple of weeks just cause some have had trouble with the MULTIS ..
So far so good..
HAVE FAITH in the bike:D
It will let you know in no uncertain terms if something is really wrong!!!
DOCC is having a track day next week I think @ Mosport, I'll bet lots of friendlies will be glad to share knowledge :)
May 26-28 Bowmanville...
thanks for the replies, I checked the antifreeze reservoir and it was full. the contents looked dark but I could be wrong. it was dark in the garage.
To have a definitive answer you could send a sample of oil to Blackstone to have it analyzed. Google then for details. Head gaskets don't just go, but everything for a good night sleep. They charge 20 bucks or so...
iF you ever get coolant in your oil you wont need to ask you wil know . It looks like dirty custard.
what they said, it's definitely not coolant.
you will know, with 100% certainty, that water/coolant got into your oil. It turns extremely milky. And believe me, it doesn't take much to make it turn.
1 - 7 of 7 Posts
