1 - 6 of 6 Posts
So I have just purchased a spare 1198 engine for my track bike ( 996/1098 engine). Is a engine rebuild possible at home. And if so is there a thread anywhere I can follow. I am tempted to try this myself over winter. I have a good amount of tools but probably will need some gauges to dial in the cams in right.
mechanical knowledge, a good manual and a set of tools and you can do anything ya want at home. some of the tools can be costly (like the primary gear puller). I have a shop at home that I do all of my work out of. I am going to tear down an ST4S motor this winter for a track build. installing a 748 transmission, lightening the primary gear and flywheel, degree the cams, set squish...all that good stuff
1 - 6 of 6 Posts
