1 - 9 of 9 Posts
I am doing an exhaust upgrade and was curious what it looked like where the sun doesn't shine. off came the header and saw the dirty valves. i am thinking they should not be this dirty. i showed pictures to the mechanic. he told me nothing to worry about, carbon build up is normal but make sure I use 93 gas. the bike run fine and the 30K service was completed last fall.
if I add some Seafoam to gas, it'll clean them up a bit?
Just Visiting Your Planet
And why did he say to use 93 (US pump grade) octane gas? Does your motor require premium? How does increasing the flash point of the gas reduce carbon buildup?
Seafoam should help clean that up some. Only benefit I would guess of using higher octane gas is some stations put more additives in the pricey stuff.
Super Moderator
I've been told (could have been lied too...never can tell) that carbon build up can be faster in the higher octane fuels because of all the extra additives in the fuel. I don't have any real data on this...just conversation. YMMV.
member
Me too. A slower burning gasoline doesn't burn off deposits as efficiently. Use the lowest octane you can without pinging or detonation.
Higher octane = good is not true. Search the tech section for interesting conversations on this topic. I run non-ethanol 91 not because of the octane, but because of the no ethanol part. If I could run 89 non, I surely would.
Anyhoo, your exhaust valves look fine...no worries!
Me too. A slower burning gasoline doesn't burn off deposits as efficiently. Use the lowest octane you can with pinging or detonation.
+1 - Carbon buildup looks normal and fine
Scott L.
Is there oil on the exhaust port for the right valve?
1 - 9 of 9 Posts
