1 - 3 of 3 Posts
Ok today I put the 900ie front axle together and I had a space on the opposite side of the speedo drive. I then tried a second axle I had and everything fit right. Now I'm wondering what axles I have?
Sandro
I've got a 2000 900, and no separate spacer is required on the non-speedo drive side. The larger OD section of the axle pulls through the fork leg and functions as the spacer,. Sounds like the 2nd one your tried is the proper one. Not sure about that first one.
Yuu
Thanks again I'm just trying to figure out what I have. It did have a speedo spacer but I was wondering what it came off of since I can't use it now.
Sandro
Sent from my iPhone using Motorcycle.com Free App
1 - 3 of 3 Posts
