1 - 3 of 3 Posts
Tightly Clenched...
Is it just the bodywork or do the frames differ enough to make it noticeable? Could you, for example, stick the F1 bodywork on the Sport chassis?
There's a 750 Sport selling on eBay that has an F1 paint job and I'm wondering if it would be an easy proposition to go further and really get the styling properly done with some replica F1 bodywork?
750Sport by satansfist, on Flickr
Untitled by satansfist, on Flickr
Without knowing the answer, I would bet that it wouldn't be easy.
The frames are different, tank different, orig. wheel sizes different. That said, If you spend the time and make the brackets etc. the F1 body should fit the Sport chassis as size wise they are pretty close in length and width. An issue with the Sport is the wheel size is 16" and the availability of good tires is limited but 17" wheels can be adapted without too much trouble.
1 - 3 of 3 Posts
