Coming from HD world I have always used both front and rear brakes, however the diavel brakes are atleast 10 times better then my lowrider's. Is there any point to using the rear brakes on the diavel?
I'm with Chuckracer and Wonway on this. Chuckracer sums it up nicely. Try these for yourself and you'll see.Does it work?
I'm a big proponent of rear brakes...critical for coming to a smooth stop without a lot of fork dive (or your passenger banging their helmet on yours), U-turns, with a combination of slipping clutch and dragging rear brake can be done full lock, no problem, and a dab mid corner if your a little hot or wide can tighten your line without chopping the throttle - important if you are on the edge of the tire.
Rear brakes are good!
