My little 748evo (1198 motor) has a poorly motor. The crank journals are damaged, as is one rod and the gearbox is a whole heap of spaghetti.
My question is will a multistrada crank fit in the 1198 crankcases? As the motor is pulled apart and mods are to be done, the hard part so far is tracing a replacement 1198 crank - But I have a lead on a multistrada crank. But will it fit? Crank balancing and machining will be done even if I do get a replacement 1198 crank.
Mike.-
Mike.-
