I need to replace the front rotors on my DB4 (warped) but realized my ignorance of brake rotors is way greater than I had thought it was. I looked up that they were 320 mm and figured I was good to go. I hadn't considered mounting bolt pattern/spacing or offset. Since no web site will list the DB4 as an application and I can't find the details of the rotors, I'm not sure how to proceed on getting the right rotors. Does anyone know the specs. on the rotors or know a good source for rotors? Maybe if you have replaced yours you could tell me what you replaced with and I can figure out the specs from that?
Thanks - Soggy
