Cutgrafix plates
Small world story: I contacted Rod at CutGrafix in late 2007 with the idea to make these and he made them decals to my order, so I have some pride of ownership on these!
My only gripe was that Rod made the decals the exact same size of the side panel that they are covering. So if the decals aren't aligned perfectly, they'll run off the edge. You have to wet mount them to slide them into place. I actually wanted number plates that were substantially smaller than the side panel, which is what NCR's New Blue cowl has. Because they had to be spot on, I chickened out had my dealer's decal guy install them and they came out perfect. If I could do it again though, I would have either sanded down the stock "Sport1000S" decal that's on the cowl because you can see it as a bump under these decals, or, alternatively, I would have had Rod shape the decal so it went around the stock "Sport 1000S" decal entirely.
