Okay, first and foremost, had a great day today at GP Motorcycles in San Diego, where they had their '2nd' Grand Opening at their new location (see signature). Among pizza, Indy GP viewing party, demo rides, was horsepower/torque/air-fuel ratio pull and/or a custom map for your bike if you had a power commander. I installed the PC V last night. So let me get right to the point.
Our StreetFighters/1098/1198's are *severely* castrated from the factory in order to come even close to passing the original EPA/Noise guidelines. As has been said in the past, we should be celebrating the fact that we can get such powerful V-twin bikes that make gobs of horsepower on pump gasoline. The cost? That area between idle & 4.5k rpm is lean. Like, really really really really freagin' lean.
The bottom line is in order to make our bikes run perfect, it won't be enough to just get slip-ons & a DP ECU. A Power Commander V or Nemesis or stand alone must be added to truely get rid of that lean issue down below. I believe that the DP ECU, even though it 'wakes up' the bike, is *still* lean below 4.5k rpm simply because Ducati doesn't want to mess with the EPA's golden territory. Get a PC V or Nemesis, now that falls on you, not them.
This chart, shows my bike with 1500 miles on it, Termignoni slip-ons and DP ECU & filter. Even though it has the DP ECU, obviously, Ducati didn't do anything to help out fuel wise from idle-4.5k. The timing is up and the fueling as you can see is rich in the midrange, so it does run a lot better there. But you can still see clearly how LEAN it is, and then how rich it is in the midrange.
Now, with the bike at 3,000 miles, WITH a power commander V installed (and let me tell you, that was a PITA to install that thing), and Louie from L&L Motorsports doing a cusom map, you can see how much cleaner the a/f ratio is....
(also, this map was done in 93 degree F*, 35% humidity....)
Notice, the a/f ratio is not all over the place. Finally rode home, and the difference is definately there, in a big way. Before, the bike took off at 4.5k rpm, now the bike takes off at just over 2k rpm...and it's smooooooooooth. Doesn't stutter and buck like it used to. Now, my bike pulls like a freight train from just over 2,000 rpm!
And the peak hp of 166.88? Even I was not expecting it to be that high! I was already happy with the prior map's 157.
To compare my bike to others that ran that day...
03 GSXR 750 - pipe & custom tune - 126
08 GSXR 750 -pipe & custom tune - 131
05 CBR 1000 - stock - 152
08 Ducati 848 - Akro slips ons, no dp ecu - 125
Triumph Tiger - stock pipe, chip, filter - 122! (not expecting that)
04 Yamaha R1 - pipe, pc - 157
08 GSXR 750 - pipe, pc - 132
01 Hayabusa - 1397 stroker motor - 204
07 GSXR 600 - cams, U4 race gas - 121
08 Ducati 1098 - Termi's, dp ecu - 150
05 MV Agusta F4 - stock - 152
I bought this bike because, honestly, I wanted a bike that was 'done' and didn't have to mess with, (you should have seen the parts list on my last bike, a cf Hayabusa) save for minor upgrades. Was really hoping the Termignoni slip-ons and dp ecu would be all that's needed, but alas, not even close. You really gotta get a PC V or Nemesis or stand alone ecu to get the fueling just right across the board.
That, and a 30 mm offset triple clamp is a must. But that's another story.
