1 - 6 of 6 Posts
Hello everyone how do you no when the cush drives need replacing. have put new chain on had it tensioned at the garage but when i change gear and put power back on it feels like it is taking slack up at the rear wheel any thoughts!
Hiya
Get the bike up on a rear paddock stand, grab the sprocket and see if you can tinktinktink it, pulling it clockwise/anticlockwise?
An excessively worn clutch basket will give you the same backlash - but you shouldnt get than with a wet clutch ;)
if i hold the back wheel there is play in the rear sprocket enough to feel it. is it a big job to replace the cush drives, are they just pushed in or screwed in.
1 - 6 of 6 Posts
