1 - 12 of 12 Posts
Been doing alot of highway driving lately and since I went back to 14t front I'm taching around 4500-5000 rpm at a steady 75-80 mph . Anyone think that's too high to just hold there......i want a overdrive button !!!
Consensus is duc's lug at 4k. Drop to a taller gear get those rpms up around 6 grand!
Sent from my Motorcycle iPad app
Not really. I can cruise at 3k rpm without problems after my open loop adjustment. 14 tooth sprocket will raise your cruising rpm.
Btw, I cruise around with 4~5k rpm on the highway in 6th and its not a problem at all.
I don't think you're really going to get a knowlegdable answer on whether or not this is safe or potentially harmful in the long run...
I certainly do quite a bit of highway cruising at these same RPM ranges and have wondered the same.
Old Wizard
In my opinion, it's perfect right where you are. You're riding dead center of the middle/peak of the Hyper's torque curve giving you the best throttle response and quickest acceleration available for changing traffic conditions.
My bike cruises at 4K under light load just fine, but any lower I consider lugging, even though it Will yank from 3500, it shakes a little, and seems happier with any load above 4000. 4500-5000 feels like the sweet spot for me for highway cruising.
Old Fast Guy
Nah, you're fine. If your hands and feet aren't going numb from hanging on, then all is well with the engine. I ride the piss out of my 1100. I'm having issues with the termi exh can blowing out the welds though!
I put most of my 20k miles on my 800 monster on the freeway, mostly between 75-85 mph. No issues with running at 4800-5300 rpm, although I did wish for a taller sixth for cruising at a lower rpm.
But don't all the Hypers run up to 8k? Can you still feel your fingers after a ride?:) I'd have thought you are fine at 4.5-5K & so is the motor.
Didn't you have a 15t before? The bigger front drops your revs a tad at the expense of acceleration & might give the motor an easier time if that's your worry.
I don't feel I've had enough time / miles on mine to really get grasp of an ideal long term set up on it (if there is such a thing). Just enjoying riding it stock & trying to make time for some longer trips. Might get into sprockets after that.
Discussion Starter #12 (Edited)
Yeah the 15t was better for highway use but the 14 is way more fun around town and back roads and the 2nd gear wheelies are fun too . I'm sticking with the 14 ( way more torque) . Just getting everyones input on holding a steady 5000 rpm's going 80 mph for longer periods of time. As far as mods , I am done !! Only thing left would be cams and pistons and I'm just not putting that kind if $$$ in a 796 !! Besides I'm more than happy anyway. My baby hyper is plenty fast for what it is .
1 - 12 of 12 Posts
