My clutch lever has a lot of stiction in it, making it hard to modulate, and it's gradually getting worse.
It's not the pivot, which is cleaned and greased. I assume it's the seals sticking. The bellows has a crack in it, so it's probably been accumulating dirt over the years. Fluid is fresh, BTW.
Assume I need to rebuild it but thought I'd check here before making a mess. Is it a PITA? Ugh, I hate brake fluid!
