21 - 30 of 30 Posts
You might consider adding an upset switch before your next race. Race bikes end up on their sides, or worse, fairly frequently compared to street bikes. There may be some room between the cylinders, and your tip-over switch could be wired in place of the side stand switch. I think the actual switches are inexpensive and compact. Just make sure you mount it solidly, it wouldn't do to have it vibrate loose!
Reactions: Racereese
2005 999S
Discussion Starter · #25 ·
Ouch! I think the broken thumb would be the worst of it, at least for me.
If one of the DKB guys can confirm that Ducati uses lead/copper bearings thats where I would start. Especially with a broken collarbone and thumb I assume it will be a minute before you will get back to racing. And Blackstone has pretty quick turnaround usually. That will at least tell you if the bearings were stressed.
Ok will do thanks and ya the thumb sucks.mostly because I am uncoordinated with that hand. And I keep bashing the dam thing lol.
2005 999S
Discussion Starter · #26 ·
Great idea.
SR71: 2005 Black ST4s, Ducati perf pkg. Weapon of Ass Destruction: 1997 Red MG Sport 1100i
If I didn't want to do a diagnostic tear down, waiting for the results of the oil analysis sounds like a good starting point. If that looked promising I would then pull the plugs and use my fiber optic scope to look at the cylinder bores. From there I would crank it over by hand and if it wasn't making any weird noises I would spin it with the starter for a few revs, with the plugs still removed and listen carefully.
That said, according to the oil flow diagram for a 999 posted in this thread...
... it looks like the oil pickup tube is located in the center of the sump, which would make it seem likely that it was sucking air while the engine was running on its side for 5 minutes. Whether the synthetic oil film would have held up at idle for that amount of time I can't say, but you may have gotten lucky with that aspect of things. At minimum the oil pump may have experienced some wear/damage. On the 996 it can be removed with minimal tear down and this may also be true for the 999.
Since I'm new to the Ducati world I have not torn one of these motors down so I don't know how much work is involved in looking at the main bearings, but since they tend to get oil first, and would thus be expected to be the first to show damage from oil starvation, they would tell you if further digging was necessary.
If I suspected that they were damaged or I just wanted to know for sure I would take the bull by the tail and tear it down. If all looks good, you have piece of mind. If it doesn't look so good, you will likely be dealing with much less damage/repair than if you just fire it up and wail on it.
2005 999S
Discussion Starter · #28 ·
I just received my oil sample kit that was recommended by this group. I just had surgery on my collarbone so I’m a few days I will be getting my sample mailed back out. As soon as results come in I will share them with you all. I have worked on cars but not on bikes. But I figure bad bearings are bad bearings. The scope thing is a great idea. Going to go get one.
I bought mine a few years ago at the Great Wal of China Mart, for about $80. Don't know if they still sell them.
I have not used the oil test kits so you may want to throw a note in explaining what you are looking for and why. OTOH, might be unnecessary...
21 - 30 of 30 Posts
