wrong stroke to start with
Reactions: paulmm600
stroke it to 803. just machine the piston crowns down a bit and lift the cylinders a touch.
that crank is also a 3 phase alt. if your 98 is a 98my then it will have a single phase. if it is a 99my it will be 3 phase.
^ all correct. Basically if you’re looking for a direct stock replacement, that won’t work. However modifications can be made for it to work and you’d gain displacement and therefore power from it.
