Corse High Performance Silicone Coolant Hoses are direct replacements for the OE hoses.
Improve the reliability and appearance of the cooling system. The Corse hoses are made from excellent quality reinforced multi-layer silicone to withstand high heat and pressure. These silicone hoses will resist cracking, splitting and deterioration that is common to standard rubber hoses, and will provide many miles of reliable service.
Operating Temperature Range up to 365 Deg F
Operating Pressure Range up to 58.8 PSI
Wall Thickness Approx. 4.5mm
Available in red, black or blue
CORSE Silicone Coolant Hose Kit 998
$120.95
Eight piece hose kit
CORSE Silicone Coolant Hose Kit 749/999
$109.95
The Corse seven piece hose kit fits 749/999(S) 03-06, 999R 04-06 with all factory radiators. Ducati supplied radiators with two different hose configurations. This kit includes hoses to fit both configurations
CORSE Silicone Coolant Hose Kit 848-1198
$139.95
Six piece hose kit
CORSE Silicone Coolant Hose Kit Monster S4
$139.95
Eleven piece hose kit
CORSE Silicone Coolant Hose Kit Monster S4RS 07-08
$139.95
Seven piece hose kit
CORSE Silicone Coolant Hose Kit: Streetfighter
$259.95
CORSE Stainless Steel Hose Clamp Kit: 998
$23.99
CORSE Stainless Steel Hose Clamp Kit: 999
$29.99
CORSE Stainless Steel Hose Clamp Kit: 848-1198
$18.99
CORSE Stainless Steel Hose Clamp Kit: Streetfighter
$35.99
Upgrade your engine coolant and protection with Motul Engine Coolant and Additives when upgrading to silicone hoses:
MOTUL MotoCool Coolant
$9.95
A ready to use cooling liquid, antifreeze and anti-corrosion for bikes cooling systems.
•No mixing necessary
•Avoid engine overheating with its high boiling point 133°C/271°F
MOTUL MoCool additive
$15.95
Top concentrated engine cooling additive that works in any cooling system of bikes, cars, ATVs.
•Reduce engine temperature by 15°C (30°F)
•Outstanding thermal exchange
•Anti-corrosion
$120.95
$109.95
$139.95
Six piece hose kit
$139.95
$139.95
$259.95
$23.99
$29.99
$18.99
$35.99
$9.95
$15.95
•Anti-corrosion
