CORSE DYNAMICS Mirror Blockoff Plates - Ducati 1199 / 899 Panigale
$54.95
Clean up the front end of your Panigale with a set of Corse Dynamics mirror block off plates.
CNC machined billet aluminum in the United States of America
Available in black anodize only
Original mirror weight - 2.5 lbs
Block off weight - 0.10 lbs
2.4 lb savings
* Mirror block off plates are also available for the
Ducati 848 / 1098 / 1198
Pair of bi-directional LED handle bar mounted motorcycle indicators from Oberon Performance that flash front and back to increase visibility. Available in black or silver. Available in black or silver for the 1199/899 Panigale.
OBERON Bar End Turn Signals Kit: Ducati 1199 / 899 Panigale
Pricing: $195.95 FREE Shipping
This kit is designed specifically for the Ducati 1199 /899 Panigale. Instead of
using the typical expanding collet design we have opted to use a large hollow
threaded aluminum bolt. The main reason for this is to save you from damaging your internal
threads on your handle bar. The additional benefit is an easier installation
since the bolt use is much larger and therefore easier to pass the wires
through. If you already have Oberon turn signals you can order just the adapters
Improved motorcycle safety
Highly visible mounted on end of handlebars
Extra wide angle viewing pattern
Visible from both front and back
Instant illumination of indicator
Small current draw
Billet Aluminum
High power amber indicator LED
Elegant design
Stainless steel fasteners
Sold in pairs for left and right mounting
By using 8 high power wide angle LED on each side of the circuit board the indicator is visible from both the front and back at the same time with equal luminosity. This has a substantial improvement on the
visibility of the indicators which adds highly to the safety of the motorcycle and rider. Mounting on the end of the handle bar provides the greatest opportunity to be seen. LED's offer a much longer life than ordinary filament indicator bulbs.
Often LED's last longer than the motorcycle in which they are fitted. With the small current draw of LED's battery life is improved. LED's do not have a time delay on operation so they are instantly on at full power.
One of the most common complaints of aftermarket motorcycle indicators is the quality of the lenses. Our unique lens envelopes the LED circuit board completely by 360 degrees providing a melt proof, shake proof and loss proof cover.
These indicators are CNC machined from billet aluminum and are available
anodized black or silver. The Indicator body size: 50mm long x 35mm dia
* Pictured with optional CRG Blindsight Mirror
* Use CORSE DYNAMICS Mirror Blockoff Plates - Ducati 1199 / 899 Panigale to cover the fairing holes when you remove the original mirrors.
Price: $47.95
Sale: $44.95 each
This New Design is used on several of our project bikes: This high quality 2" Rearview mirror was designed to work with virtually any motorcycle, and replaces unsightly, or poor functioning original equipment motorcycle mirrors. Now built with high quality automotive convex mirror glass which works surprisingly well. Black Anodized billet aluminum construction.
The smaller Blindsight will fit OEM and after market monster bars without adapters by sliding the controls up. Priced each.
Mounting options:
Mount these directly on the bar by sliding up the controls or use the optional CRG adapter to mount on the end.
RhinoMoto makes a special bar end slider for the CRG mirror that allows you to clamp the CRG mirror on the bar end slider instead of the bar. OBERON also makes a bar end turn signal that has provisions for bar end mirrors.
* Register on the Motowheels website for Free forum passwords to access discounts on most non sale items or VIP passwords for the deepest discounts on all items. Look for memberships and choose the membership type that fits you the best
