CORSE DYNAMICS Full Floating Rotor Button
Pricing: $9.95 * each
Made of air craft grade 7068 Hard Anodized Aluminum
Free floating brake buttons will allow you to convert semi floating rotors into full floating rotors. Free floating rotors reduce the drag from the pads which in turn reduces the heat build up in the rotors and the heat transfer to the fluid which often causes brake fade. The buttons will also eliminate stuck buttons which also cause brake pulsing at the lever. These free floating buttons will allow the bike to roll easier with less drag from the pads/rotor blade and reduce the unsprung rotating weight by over .5 pound per rotor on most rotors.
Hard Anodized aluminum buttons with stainless steel clips
Designed for all Brembo rotor applications OEM & Aftermarket with 5mm thickness.
Sold each. Count the number of buttons on your order to determine how many buttons you need.
Check the documents tab on our website for crucial tolerance measurements for special applications - and the installation video
* Register on the Motowheels website for Free forum passwords to access discounts on most non sale items or upgrade to lifetime VIP passwords for the deepest discounts on ALL items. Look for memberships and choose the membership type that fits you the best
