Two is really better than one. This simple jam nut solution will fix the common Ducati problem that can lead to big problems if not taken care of.
CORSE DYNAMICS Flywheel Jam Nut Set: Ducati
Pricing: $35.95
The factory flywheel nut supplied by Ducati for lack of better terms is out of spec. There are several crucial dimensions that make up the compatibility of two threads. Ducati has matched the size and the pitch but that is about it, because of this lack in quality of the flywheel nut, flywheels are known to come loose, and when they do come loose they mar threads and splines on a very expensive crank shaft. Crank shafts are expensive, as is the labor for complete disassemble of the motor and splitting the crank cases for installation.
Corse Dynamics has CNC machined 4130 chromoly steel to an extremely high tolerance specification to ensure your jam nuts will serve their purpose for years to come. After machining, the nuts are heat treated in order to increase strength & durability. EVERY nut is hand inspected to ensure all crucial dimensions meet specifications, these nuts are proudly made and inspected in the USA.
Works with all OEM or aftermarket flywheels
* Outside continental USA, use shipping coupon codes:
* Register on the Motowheels website for Free forum passwords for discounts on most non sale items or lifetime VIP passwords for the deepest discounts on all items . Look for memberships and choose the membership type that fits you the best
