Corse Dynamics LED headlight kit. Fits the OEM headlight bucket on Ducati Monster and Sport Classic with metal bucket only.
CORSE DYNAMICS 7 Inch LED Spada Headlight w/ Adapter ring
Was: $499.94
Sale: $299.99 * FREE Shipping
When properly mounted, exceeds FMVSS-108 and CMVSS-108 DOT requirements for low beam and high beam performance.
Excellent option for your motorcycle.
Metalized reflector optics provide a lighting experience that's smooth and clean across the driving surface.
Provides a brighter, crisper and whiter light output, closer to the color temperature of daylight, dramatically improving light projection distance and overall visibility
Durability and dependability of LED lighting provides a solid-state, bulb-free headlamp design that impervious to damage from shock and vibration.
Military grade, die-cast aluminum housing and non-yellowing, polycarbonate lens offer optimum protection against damage from impact, roadside debris and other hazards.
Electronics are sealed in epoxy to resist from damage caused by corrosion or moisture.
Advanced circuitry protects against voltage spikes up to 600v.
Uses standard, H4, 3-blade wiring connector
Includes a 3-Year Limited Warranty
Includes an adapter ring to fit the larger Ducati OEM round steel headlight headlight as used on most first generation Ducati Monster and early Sport Classic. Must re-use the stock steel bucket, outer ring, and spring clips.
* Outside continental USA, use shipping codes:
* Register on the Motowheels website for Free forum passwords to access discounts on most non sale items or lifetime VIP passwords for greater discounts on more products.
Look for memberships and choose the membership type that fits you the best
