Has anyone installed these on an 02-03 ST4S and be able to use the stock length braided steel lines? I would like to use them in the 7 deg back position as well. I think I recall that the 1/2" versions did not require longer lines but a quick forum search did not exactly confirm that for my application.
Another slightly different question - does anyone have experience which configuration get the bars closer to you; the Corse Dynamics/ Dr Desmo style which rotates the bars back 7 deg around the axis of the fork tube, or the Mike Shannon style which rotates the bars back 7 deg around a horizontal axis via wedge shaped risers?
Thanks
Paul R.
Thanks
Paul R.
