Is it 71Nm for the 12mm nut on the cam belt tensioner for my 2000 748?
looking through the manual thats the only reference I can find on anything that looks like int may be the cam bet tensioner nut.
thanks
Somewhere between 1/4 and 1/2 turn after the initial toque of the nut setting into the washer.
Replace the wavey washer between the nut and pulley mount. I seldom do it and have not run into an issue with reuse of the washer 4 or 5 times. But replacing it is good advice.
Thanks Guys, I thought 71 seemed high for that nut, hence my question.
Appreciate the quick reply
