Anyone know offhand the equivalent replacement for the coolant temperature sensor (the EFI unit, not the fan switch)?
Also does it make sense it is the culprit if I intermittently (but regularly) get sputtering, lack of power, and stalling? Happens when cold or hot but not all the time. I believe it's to blame because wiggling the connector or disconnecting the switch will recreate the issue (I already tried cleaning the contacts and zip tying the connector tight but the issue remains).
The last time it failed it behaved differently so I'm not 100% sure it's the problem. When it last crapped out the bike would run normally until the temperature went over 120-140, then it would cut out under acceleration. Didn't stall or sputter the same way. It's also afterfiring significantly on overrun, with the odd backfire through the intake.
I've already changed the fuel filter, lines and o-rings to rule them out.
