Update:, Been busy steadily working on the SSS 821 project. FYI, when doing this conversion you must also order the brake caliper line from the donor bike, in my case the Monster 1200S. Normally the brake caliper is on the right hand side, single sided on the left, so the brake line will be too short if you don’t change. This brake line is a pain as it runs to the ABS unit under the air box which needs to be removed. Quite a lot of work. Also worth noting, my old Brembo caliper is a direct fit to the SSS. Also, on the Brembo caliper the banjo fitting bolt and the air bleed nipple are interchangeable with each other. Good to know, so place them where they work best for you. Adding some eye candy like Titanium axle bolts and pins. They don’t corrode, always look good, save weight, and since they don’t corrode will be easier to take off.
