Ok I need some opinions....I am considering between 2 ST4S's...one is a 2003 with low miles (7K)...been dealer serviced and in good shape....the other is about $600 more and is a 2002 with 22K; however, the engine was completely rebuilt by a supposedly reputable shop only a couple of thousand miles ago (due to a lower end bearing failure). The guy who is selling this one seems to know a lot about Ducatis and has gone through it changing out the wheel bearings/ taper steering bearings, brake pads full suspension service with gold valves, lubricated swingarm bearings, radiator kit, kickstand bypass, low effort clutch slave, replaced cam belts, fuel filter and lines, replaced fueld pump and radiator fan relays, replaced starter cables and coolant sensors. It also comes with Sargent seat, carbon pipes and the DD headlight.
I am not as concerned about resale value as I am about longevity between these two.
My question to you guys is...would you rather have a lower mileage but more stock motorcycle or a higher mileage with those custom parts and rebuilt one?
