1 - 2 of 2 Posts
Hey All,
I recently invested in the Termingoni slip-on kit with air filter and ECU and when it arrived it was labelled for the 848 Evo. I however have the 848. When I installed the ECU I got the the repair code set EXVL and set Unit. So I rebooted the bike holding the mode button to see if the gauges work. Success, display reads 848 EVO DP. However, when I toggle through the settings I got the error strt 19.2. Thinking it was the starter contactors I put the old ECU back in and she fired up. My question is; could there be something wrong the ECU, Is it compatible with the 848 or is there some programming that the dealer has to do with the Ducati Diagnostic System. to "map" the new ECU.
Thanks Guys
I hope it's clear as to what my issue is :)
Did you have any success figuring out how to resolve this?
My friend ordered the same kit for his 2008 848 and the ECU says STRT 19.2
He now thinks he ordered or received the kit for the EVO (2011-) which would have a different ecu or different programming.
he ordered off ebay, so not clear if he will be able to exchange for correct ecu.
Can a dealer/tuner just reprogram 2011 ecu to work with 2008?
We are in SF bay area, ca so fastline cycles is nearby, as well as duc shops.
1 - 2 of 2 Posts
