1 - 7 of 7 Posts
Are the throttle cables of the 1098 compatible with the 999? From what I understand is that they only have a different curving and the end of the cable (the side which is connected to the throttle bodies). The 999 is straight whereas the 1098 is bend.
TOTALLY different. And the 1X98 are shorter by about 150mm. Throttle cam on the 999 is on the vertical throttle body and the throttle cam on the 1X98 is on the horizontal throttle body. The 1X98 doesn't have a cable operated fast idle lever.
1 - 7 of 7 Posts
