1 - 3 of 3 Posts
I want to trim the CO on my SF using a rexxer module,my question is can I use a automotive gas analyser in one of the tail pipes to measure the co, I work in a car dealership and it would be handy rather than buying a bike specific tester
Why not? It would probably be more accurate. There are small analyzer taps in both pipes. Use them rather than putting the probe down the mufflers.
That's my thinking too and it'll cost me nothing,I've two other questions if I may,firstly it's the air fuel ratio I want to optimise right,is 13.5 a good figure to try obtain ? And secondly before I do this want to reset my TPS which I've done already after the install and I want to now balance the throttle bodies and adjust the air bleed screws so what I'm wondering is .... What's the function of the bleed screw adjustment and should I copy the redline reflash bleed screw position that I've read here even though I'm using a rexxer
Thanks !
1 - 3 of 3 Posts
