On my 2000 ST2, I had the good ole fashion squawking clutch (As you slipped the clutch from a start, it sounded like a chair being dragged across a hardwood floor). I read up on the lithium grease trick last summer and figured I would give it a try. For a while it worked great. No more squawking. Then at the beginning of this year, the clutch started sticking on me. I would pull in the clutch and then half a second later the disks would finally separate and disconnect the rear wheel from the transmission. I pulled the clutch apart and several plates were sticking together (one clump of four plates came out of the basket together and took some effort to separate). With a liberal dose of brake cleaner on all the disks, I cleaned it up as best I could and put it back together. The bike ran good again and I only had the slightest hint of a squawk.
The the squawking got louder...
... and more present...
... and then it was EVERY time that I started from a stop and every time that I rode the clutch.
... and then it started slipping.
SO, I pulled the clutch back apart today. All the fiber disks look to be in good shape (My digital calipers have dead batteries so I haven't been able to measure them yet), but it is the metal disks that I am concerned about. They are very dark and very shiny. Almost mirror smooth. Have I fried these disks, or can they be glaze busted? Or do they need to be?
Pics to come...
Pics to come...
