Clutch soft
1329 3
So I’m on the road... warm day and the clutch is soft... fluid is in reservoir. Any “easy bleed on the road”? Maybe open top bleed and let fluid gravit feed? Not sure why its soft in the first place either.
Probably got a small leak down at the slave cylinder, common problem on older Ducati's.
Is the actual clutch working properly? Sometimes the tangs on the clutch basket can develop ridges and sometimes the plates don't retract properly after you've squeezed the clutch lever, but if the bike os driving forward properly, I'd bet it's the slave cylinder.
Reactions: complexCarlo
Do you have any brake fluid with you? What about a short flexible tube that'll fit over the bleed nipple, and a 10mm wrench? You can bleed the clutch like the brake. Pull the clutch all the way to the grip, open and close the nipple, release the clutch, pump, repeat. Could try one or two openings of the bleed nipple to see if you've got air in there.
I just had to bleed my clutch this weekend. Bike was starting to get hard to shift into first, and finding neutral was difficult. Same symptoms as a clutch cable needing an adjustment.
Cluch fluid was cooked... we swapped it last night and now just getting the air out.
