So on a past ride this weekend I noticed that my bike (2007 Monster S4RS) was having some major issues when accelerating. I would get on the gas, the engine would spin but the bike would not accelerate. The bike would accelerate only when I gently got on the gas, which from what I read points to the clutch slipping.
I got home, took the thing apart and started measuring the plates and springs per troubleshooting tips found on the shop manual. The individual clutch plates thickness measured 2.8 mm to 2.9 mm on some areas.
The entire clutch pack measured 28.1 mm to 29.00 mm depending on where I measured.
According to the shop manual the minimum thickness should not be less then 2.8 mm per plate, which none of my plates exhibited but are very close to. I checked the springs and none of them where below the manuals 36.5mm free play lenght minimum.
I don't know much about dry clutches but based on the information provided should I go ahead an order a new clutch pack? Is the thickness of my plates to close to the limit which could be causing the slipping?
Any feedback is appreciated.
