Hi All. I've had no complaints about my clutch action, but after running low on fluid I took off the clutch slave and found the rubber gaiter behind it eaten by the chain. I read some old posts here, and appreciate the idea of a new c. slave with a clean and easy double sealed piston, but as I have no other complaints about the stocker, a gaiter, and possibly fluid seal (and inner seal if I can figure out how to get it out..) would make me very very happy. I haven't seen a lead on where to find the rubber parts. Any clues? Also I see that ca cycle works sells a metal piece that looks like it would would protect from repeat chain damage to the gaiter www.ca-cycleworks.com/shop/catalog/ducati/img/case_saver.jpg anyone ever used it? Or does an upgraded clutch slave do away with a gaiter all togeather?
As it still has to be considered a new bike for me, with band new 14/39 sprockets and chain with old 180/55 Dunlop I'm wondering if the new sprocket installation is to blame for the situation. I also noticed the chain is amazingly
close to the edge of the back tire, and looks like it's chewed off a bit along the outer most corner edge. Is it possible to adjust or shim the chain away from tire?
best to all
N
best to all
N
