I'm looking to slap on the Oberon clutch slave (29mm) on my 2009 GT and have done quite a bit of research. I like my lever set at 4, the smallest span, and am hoping I can keep that setting and still get enough clutch separation to not cause problems. This is unlikely.....but wouldn't new clutch lines help out? Some braided steel ones, so some of the oil pressure is not lost to the rubber hoses expanding? I'd imagine that bit of lost pressure could be the difference between problematic slippage and acceptable slippage.
Also, I wonder if the wet clutches make a difference in acceptable clutch slippage? Anybody out there have direct experience with the oberon 29mm slave on a stock 2009 GT?
