OK so I got a 30mm slave for the clutch and when I put it in the piston would touch the case before the rod would disengage the plates.
Anyway, I made a small shim about 11-12mm and put it in the button on the pressure plate side.
Works
My questions are:
Why did I have to do this?
and what rod should I be looking to order to get rid of my shim (mainly because the difference is really 15-16mm but I cannot use a larger shim in that button)
Works
My questions are:
