1 - 10 of 10 Posts
I am an instructor for a trackday organization and on 1st june I was attending a trackday at Loudon, NH. After about 4 or 5 sessions in 85 degree weather, it became tough to get my 2003 999S into neutral. A little later in the day, the bike started to try to pull away as soon as I got it in gear unless I REALLY pulled the clutch lever all the way to the handlebars.
My question is this: Do I need to replace the clutch plates, or should I be looking more at the slave cylinder and bleeding the hydraulics? I'm a competent mechanic, but I'm new to Ducatis and I don't have any experience with dry clutches or hydraulic clutches.
The bike has 9k miles on it and all the clutch components are stock as far as I know. I don't mind spending a bit of cash on parts that are going to give me a quality or performance improvement, but I'm not going to blow cash on bling.
Any suggestions on how far I should go on a clutch rebuild? Should I get an aftermarket slave cyl? Ducati original plates or aftermarket? Is a vented cover a good idea?
Thanks in advance for any and all advice.
comrade moderator
Sounds like it's time for fresh fluid and a good bleed. Your plates and stuff are fine...it's a dis-engagement problem, not an engagement problem.
Great! Being a cheap sumbitch that is music to my ears. Thanks!
Any recommendations on fluid?
derek
comrade moderator
He he...yeah, I hear that! Naw, any new, sealed container Dot3 will be fine. I really can't believe there is any difference between the Dot3 available at an auto parts store, and the more expensive stuff...maybe someone here can shed some more light on choices?
Well, I have some AP racing 600 that i believe is dot 4 or 5. I'll have to check, and look in my service manual to see what they spec out.
comrade moderator
If it's not fresh, buy some new stuff or you'll run into the same problem very soon. Brake Fluid absorbs moisture like a mad mo-fo when not in a sealed container.
Definitely do a complete flush...
I normally just use any old DOT4... or a DOT5.1 would work.
I like Valvoline DOT 4. I saw comparison chart [somewhere...I can't find it in this mess] showing it had a higher boiling point. I run it in both my clutch and brakes under pretty severe conditions, and it holds up. you should be able to get it anywhere. I get mine at *cringe* Autozone.
Discussion Starter #9
Thanks to all for the advice. I bought a mityvac, a bottle of Valvoline DOT4 and had the old dirty goo out of there and new fresh stuff in, in about 15 minutes. Good as new.
derek
+1
1 - 10 of 10 Posts
