OK , so I think I made things worse , bike is 92 Ducati 851 7500mi
Replacing the gaitor boot on Clutch slave cylinder and pushrod , and I replaced the 2 little rings on the clutch side of the push rod.
Got the 2 seals and pulled off the slave cylinder , no oil leak, removed the pushrod and replaced the 2 rings and re-installed everything in sequence.
Start the engine in neutral , the dry clutch pack spins freely,
put it in gear and it stops !
Let out the clutch a little and the clutch begins to move but then engine stalls.
Am I just stupid or hamfisted or retarded , can't figure it out and I am tired of screwing things up.
any advice again would be welcome.
