I just added an '06 S2R1000 to my garage, along with my ST2. I recently swapped the CycleCat pressure plate and cover from the ST for the stock setup on the S2R. The clutch plate with the pushrod went onto the S2R without a problem and works perfectly. However, when I put the stock plate and pushrod onto the ST the pushrod just goes into the drum and there's no spring or tension pushing it back. The clutch lever has no tension when you pull it in either and the clutch fluid is now low.
Any ideas what could be causing this and how I fix it?
Thanks,
Thanks,
