I took my clutch pack out last night because there is some clank going on at low rpm when I'm taking off. It appears to be the original clutch. Yeah, 21k on the bike. The basket (also own) has the expected grooves but it looks okay for its age. The plates have the one side of the teeth bashed in and the friction material is barely there to non existent. The throw out bearing is fine. Smooth and no notchy feeling there.
So now my question. I know its not preferred to put an aftermarket aluminum pack like a barnett in there without replacing the basket because the teeth on the plates will wear prematurely. But how prematurely are we talkin about here? I drive maybe 100 miles a month, and I'm not that aggressive with it yet. Will it be okay for 6 months so I can save some money to get the basket and the rest of the blingy stuff? Or should I just clean the plates and flip them around? Is there anything bad that can happen if I let it go too long without changing them, like parts shearing apart and destroying my case?
Sent from my HTC Evo 4G
