I had a separate thread going about clutch lever going soft after 300 miles. Seems a common occurrence based on the numerous posts I found.
According to several sources (OPP Racing, for one), Brembo rebuild kits are no longer made available from the manufacturer. But... there was a recall for the 16mm brake MC piston, which coincidentally is the same as the clutch master. Because of the recall, it is possible to get the rebuild kit (part #61041881A) for $20. Worth noting that the kit comes with the dust seal that otherwise costs $25 from the dealer.
I haven't confirmed yet, but am hopeful this will resolve the soft lever issue.
Here are details on the recall, as well as the rebuild procedure:
https://static.nhtsa.gov/odi/rcl/2017/RCSB-17V812-2711.pdf
